Configure Route Dominance Rules (Location Referencing Tools)
Summary
Configures a set of rules to determine the dominant route in a network where there are concurrent routes.
Usage
  • The Order Type parameter's Numeric option supports numbers only, such as 1, 2, 11, 22. The Alphanumeric option supports both numbers and text, such as 1, 2, 11, 22 and 1, 11A, 22A, 22B.
  • When multiple fields are configured using the Fields parameter, the field values are concatenated in the order in which the fields were added. For example, if the RouteType field is added first and has a value of SR and the RouteNumber field is added second and has a value of 18, the resulting concatenated field is SR18.
    For example, if SR18 is a multifield route ID that comprises the RouteType (SR) and RouteNumber (18) fields, select RouteType and RouteNumber for the Fields parameter.
  • When the Prioritized Exceptions parameter is populated, route dominance is determined first by matching exceptions in the order in which they are present in the list, and then by the configured rules. The exception field values are in a comma-separated list.
    For example, if Prioritized Exceptions values are configured for Route3, Route7, and Route9, the exceptions are considered as dominant routes in their listed order before any configured rules are considered.
Parameters
Label Explanation Data type
LRS Network Feature Class
The input feature class. Only a registered LRS Network feature class can be used.
Feature Layer
Configure Type
Specifies the type of configuration that will be applied to the LRS Network Feature Class parameter value.
  • Add—A new rule will be added to the configuration.
  • Update—An existing rule will be updated in the configuration.
  • Delete—An existing rule will be deleted from the configuration.
String
Rule Name
The name of the rule that will be added, updated, or deleted. The rule name can be up to 30 characters.
String
Updated Rule Name
(Optional)
The updated name of the rule. This parameter is only used when Update is specified as the Configure Type parameter value.
String
Source Table Name
(Optional)
The source event table or feature class registered to the LRS Network Feature Class parameter value. Alternatively, the network feature class can be used. Only nonspanning line events are supported.
String
Fields
(Optional)
The attribute field aliases in the source table. If multiple fields are used, they will be concatenated.
String
Order Method
(Optional)
Specifies whether the route dominance order will be determined by lesser or greater values.
  • Lesser—The route dominance order will be determined by lesser values. This is the default.
  • Greater—The route dominance order will be determined by greater values.
String
Order Type
(Optional)
Specifies the order type that will be used when evaluating numeric or alphanumeric strings.
  • Alphanumeric—The alphanumeric order type will be used. This is the default.
  • Numeric—The numeric order type will be used.
String
(Optional)
A comma-separated list of user-provided exceptions.
String
Derived output
Output Network Feature Class
The updated LRS Network feature class.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
