Create LRS From Existing Dataset (Location Referencing Tools)
Summary
Creates a linear referencing system (LRS) in the specified workspace using existing datasets.
Usage
  • Minimum schema items are used for the centerline, centerline sequence, calibration point, and redline feature classes. Ensure that the items are empty, contained in the same geodatabase, and not used by another LRS in the geodatabase.
  • Centerline, calibration point, and redline feature classes must reside in a feature dataset.
  • The spatial reference, tolerance, and resolution of the centerline, calibration points, and redline feature classes must be the same.
  • The centerline and calibration point feature classes must be z-enabled and can be m-enabled.
  • The redlinefeature class must be z-enabled.
Parameters
Label Explanation Data type
LRS Name
The name of the LRS to create. The name cannot already exist in the geodatabase.
String
Centerline - Feature Class
The feature class to use as the centerline in the LRS.
Feature Layer
Centerline - Centerline ID Field
The GUID field containing the centerline ID. The field type must match the centerlineID field type in the centerline sequence table.
Field
Centerline Sequence - Table
The table to use as the centerline sequence in the LRS.
Table View
Centerline Sequence - Centerline ID Field
The GUID field containing the centerline sequence ID. The field type must match the centerlineID field type and length in the centerline feature class.
Field
Centerline Sequence - Route ID Field
The GUID or text field containing the centerline sequence route ID. The field type must match the routeID field type and length in the calibration point and redline feature classes.
Field
Centerline Sequence - From Date Field
A date field containing the centerline sequence from date.
Field
Centerline Sequence - To Date Field
A date field containing the centerline sequence to date.
Field
Centerline Sequence - Network ID Field
The field containing the centerline sequence network ID. The short integer field type is supported.
Field
Calibration Point - Feature Class
The feature class to use as the calibration point in the LRS.
Feature Layer
Calibration Point - Measure Field
The field containing the calibration point measure. The double field type is supported.
Field
Calibration Point - From Date Field
A date field containing the calibration point from date.
Field
Calibration Point - To Date Field
A date field containing the calibration point to date.
Field
Calibration Point - Route ID Field
The field containing the calibration point route ID. GUID and text field types are supported. The field type must match the routeID field type and length in the centerline sequence table and the redline feature class.
Field
Calibration Point - Network ID Field
The field containing the calibration point network ID. The short integer field type is supported.
Field
Redline - Feature Class
The feature class to use as the redline in the LRS.
Feature Layer
Redline - From Measure Field
The field containing the redline from measure. The double field type is supported.
Field
Redline - To Measure Field
The field containing the redline to measure. The double field type is supported.
Field
Redline - Route ID Field
The field containing the redline route ID. GUID and text field types are supported. The field type must match the routeID field type and length in the calibration point feature class and centerline sequence table.
Field
Redline - Route Name Field
A text field containing the redline route name.
Field
Redline - Effective Date Field
A date field containing the redline effective date.
Field
Redline - Activity Type Field
The field containing the redline activity type. The short integer field type is supported.
Field
Redline - Network ID Field
The field containing the redline network ID. The short integer field type is supported.
Field
Derived output
Output Location
The path of the newly created LRS Network.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
