Generate Linear Referenced Feature Count (Location Referencing Tools)
Summary
Creates a feature count data product for routes in an LRS Network without an LRS data template.
Usage
  • This tool supports data from a file geodatabase, an enterprise geodatabase (branch versioned connection), or a feature service (published from branch versioned data).
  • This tool does not modify the inputs and will create a .csv file or a geodatabase table as the output.
  • The Effective Date parameter is used to define the temporal view of the network. Only routes active on this date will be used to calculate the output.
  • The summary layer must be a polygon feature class, an LRS line event feature class that is registered to the specified LRS Network, or an LRS Network.
  • A value of unclassified will be included in the output summary field for routes that do not overlap with the summary layers.
  • You can add multiple summary fields.
  • The output will be created based on the intersection of selected features from the LRS Network, summary layers, and feature count layers.
  • The feature count layer must be an LRS point event feature class, an LRS line event feature class, or an LRS intersection feature class that is registered to the specified LRS Network.
  • A value of unclassified will be included in the output feature count fields for routes that do not overlap with the feature count layers.
  • The summary and feature count layers must be stored in the same geodatabase or feature service and have the same coordinate system as the specified LRS Network.
  • You can add multiple feature count layers from the same feature class by creating selection layers and specifying each selection layer as a feature count layer. For example, if you have an LRS point event feature class, you can create two selection layers—Class A and Class B—and specify each selection layer as a feature count layer.
Parameters
Label Explanation Data type
Input Route Features
The route features that will be used to create the feature count data product.
Feature Layer
Effective Date
The date that will be used to define the temporal view of the network.
The default value is today's date.
Date
Summary Fields
(Optional)
The fields that will be used to show the names for the summary rows in the output.
Value table columns:
  • Layer—The feature layer that will be used as the summary layer.
  • Field—The field that will be used to summarize the feature count.
  • Output Field Name—The summary field's display name in the output.
Value Table
Feature Count Layers
(Optional)
The layers that will be used to locate the number of features along a route.
  • Layer—The feature layer that will be used as the feature count layer.
  • Output Field Name—The feature count layer's display name in the output.
Value Table
Exclude null summary rows
(Optional)
Specifies whether null summary rows will be excluded from the output.
  • Checked—Rows that have only zero feature counts (null summary rows) will be excluded from the output. This is the default.
  • Unchecked—Rows that have only zero feature counts (null summary rows) will not be excluded from the output.
Boolean
Output Format
(Optional)
Specifies the format of the output.
  • CSV—The output will be a .csv file. This is the default.
  • Table—The output will be a geodatabase table.
String
Output File
(Optional)
The output .csv file that will contain the feature count data product.
File
Output Table
(Optional)
The output geodatabase table that will contain the feature count data product.
Table
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
