Generate Linear Referenced Length Summary (Location Referencing Tools)
Summary
Creates a length data product for routes in an LRS Network without an LRS data template.
Usage
  • This tool supports data from a file geodatabase, an enterprise geodatabase (branch versioned connection), or a feature service (published from branch versioned data).
  • This tool does not modify the inputs and will create a .csv file or a geodatabase table as the output.
  • The Effective Date parameter is used to define the temporal view of the network. Only routes active on this date will be used to calculate the output.
  • The summary layer must be a polygon feature class, an LRS line event feature class that is registered to the specified LRS Network, or an LRS Network.
  • The length layer must be an LRS Network or an LRS line event feature class that is registered to the specified LRS Network.
  • The summary and length layers must be stored in the same geodatabase or feature service and have the same coordinate system as the specified LRS Network.
  • A value of unclassified will be included in the output summary field for routes that do not overlap with the summary layers.
  • You can add multiple summary fields.
  • The output will be created based on the intersection of selected features from the LRS Network, summary layers, and length layers.
  • You can add multiple length fields from the same feature class by creating selection layers and specifying each selection layer as a length field. For example, if you have an LRS line event feature class, you can create two selection layers—Class A and Class B—and specify each selection layer as a length field.
Parameters
Label Explanation Data type
Input Route Features
The route features that will be used to calculate the LRS length data product.
Feature Layer
Effective Date
The date that will be used to define the temporal view of the network.
The default value is today's date.
Date
Length Units
Specifies the measure unit that will be used for the length fields in the output.
  • Inches (US Survey)—The units will be inches.
  • Feet (US Survey)—The units will be feet.
  • Yards (US Survey)—The units will be yards.
  • Miles (US Survey)—The units will be miles.
  • Nautical Miles (US Survey)—The units will be nautical miles.
  • Feet (International)—The units will be international feet.
  • Statute Miles—The units will be statute miles.
  • Millimeters—The units will be millimeters.
  • Centimeters—The units will be centimeters.
  • Meters—The units will be meters.
  • Kilometers—The units will be kilometers.
  • Decimeters—The units will be decimeters.
String
Summary Fields
(Optional)
The fields from the layers that will be used to show the names for the summary rows in the output.
Value table columns:
  • Layer—The feature layer that will be used as the summary layer.
  • Field—The field that will be used to summarize the length.
  • Output Field Name—The summary field's display name in the output.
Value Table
Length Fields
(Optional)
The fields from the layers that will be used to show the length of the routes in the output.
  • Layer—The feature layer that will be used as the basis for calculating the length.
  • Output Field Name—The length field's display name in the output.
Value Table
Exclude null summary rows
(Optional)
Specifies whether null summary rows will be excluded from the output.
  • Checked—Rows with a zero length (null summary rows) will be excluded from the output. This is the default.
  • Unchecked—Rows with a zero length (null summary rows) will not be excluded from the output.
Boolean
Calculate length for dominant routes
(Optional)
Support for this parameter will be added in a future release.
Boolean
Output Format
(Optional)
Specifies the format of the output.
  • CSV—The output will be a .csv file. This is the default.
  • Table—The output will be a geodatabase table.
String
Output File
(Optional)
The output .csv file that will contain the length data product.
File
Output Table
(Optional)
The output geodatabase table that will contain the length data product.
Table
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
