Modify Network Calibration Rules (Location Referencing Tools)
Summary
Modifies the network calibration rules for an LRS Network.
When creating an LRS Network, you can choose how gapped routes are calibrated while creating or editing routes. Using this tool, you can configure calibration rules for a network after the LRS Network has been created and during the data loading process.
Learn more about creating and modifying an LRS Network in ArcGIS Pipeline Referencing or creating and modifying an LRS Network in ArcGIS Roads and Highways.
You can use any of the following methods to calibrate routes with physical gaps:
  • Stepping Increment
  • Adding Increment
  • Euclidean Distance
Each method will produce a different calibration value for a route with physical gaps created using the LRS editing tools. The example below shows the calibration of a route created from a centerline with physical gaps for each calibration method and calibration of a route with retirement between the measure 0.5 and 1 for each calibration method.
In the retire route scenario, a physical gap is created between the measures 0.5 and 1. The calibration rules are applied only if a physical gap is introduced due to an editing activity and do not affect the existing gaps. In the example, the gap between measures 2 and 2.5 remains unaffected due to retirement.
Usage
  • The following tables show the results of gap calibration using the Create Route and Retire Route panes after setting up rules using this tool.
    Create a route with physical gaps
    Create route
    Example calibration
    Stepping Increment of 0.1
    A measure value of 0.1 is added to the first measure after each physical gap.
    Adding Increment of 0.1
    A measure value of 0.1 is added to each measure after each physical gap.
    Euclidean Distance
    Euclidean Distance
    A measure value equal to the straight-line distance of the physical gap is added to the first measure after each physical gap.
    Legend
    Retire a route between measures 0.5. and 1
    Retire route
    Example calibration
    Route before retirement creates a physical gap
    Route before retire creates a physical gap
    The retire portion of a route shown before a physical gap is created using the Retire tool.
    A measure value of 0.1 is added to the first measure after the physical gap.
    A measure value of 0.1 is added to each measure after the physical gap introduced due to retirement.
    Euclidean Distance
    Euclidean Distance
    A measure value equal to the straight-line distance of the physical gap is added to the first measure after the physical gap introduced due to retirement.
    Legend
  • This tool supports setting the gap calibration rule and the calibration offset for the specified network.
  • Typically, network calibration rules can be modified once the network is created. Changing the calibration rule will apply the new rule only to routes edited or loaded in the future. All routes edited or loaded previously will not honor the new calibration rule. They honor the calibration rule set at the time of their creation or editing.
  • You can use the As Is option in the Calibration Rule parameter to retain the existing gap calibration method with an option to change only the calibration offset value pursuant to requirement.
  • The Calibration Offset parameter must be set for the adding increment and stepping increment methods. The values must be numeric, with or without decimals; negative values cannot be used.
  • The Calibration Offset parameter value cannot be set less than or equal to the m-tolerance of the network. It can be either zero or greater than the m-tolerance value of the network.
  • Defining the Calibration Offset parameter value as zero (0) will produce a route with no gap in calibration measure at physical gaps.
  • The default gap calibration rule for an LRS Network is Stepping Increment with an offset value of 0.
  • This tool is not supported with feature services.
Parameters
Label Explanation Data type
LRS Network Feature Class
The input LRS Network feature class.
Feature Layer
Calibration Rule
(Optional)
Specifies the method that will be used to define calibration gap measures.
  • As Is—The existing defined method in the network will be used while changing the calibration offset value.
  • Adding Euclidean Distance—The Euclidean, or straight-line, distance will be calculated and added at each physical gap along an edited route.
  • Stepping Increment—A value will be defined that will adjust, or step, at each physical gap in the route. This is the default.
  • Adding Increment—A value will be defined and added to each measure of a route at each physical gap, in addition to the total length of the from and to measures of the route.
String
Calibration Offset
(Optional)
The value of the Calibration Rule parameter's Adding Increment or Stepping Increment method. The increment value must be numeric and can include decimals.
Double
Update route measures in cartographic realignment
(Optional)
Specifies whether or not to recalibrate route measures based on length changes in cartographic realignment.
  • As is—The existing defined method in the network will be used. This is the default.
  • Enable—Enable recalibration of route measures based on length changes in cartographic realignment.
  • Disable—Disable recalibration of route measures based on length changes in cartographic realignment.
String
Derived output
Output Network Feature Class
The updated network feature layer.
Feature Layer
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
