Build Network (Network Analyst Tools)
Summary
Reconstructs the network connectivity and attribute information of a network dataset. The network dataset must be rebuilt after edits are made to the attributes or the features of a participating source feature class. After the source features are edited, the tool establishes the network connectivity only in the areas that have been edited to speed up the build process; however, when the network attributes are edited, the entire extent of the network dataset is rebuilt. This may be a slow operation on a large network dataset.
Learn more about which network dataset edits require a rebuild
Usage
  • If build errors are encountered when building the network, a warning message appears. Review and address these errors, as they indicate potential problems that may prevent the network from working as intended.
    Learn more about network build errors
  • To build a file geodatabase network dataset, an exclusive schema lock is required on the network dataset and the participating source feature classes. This means that no one can be editing the participating feature classes. An error will occur if an exclusive schema lock cannot be obtained. Network datasets in enterprise geodatabases support multi-user editing and do not have the same requirement for exclusive schema locks.
Parameters
Label Explanation Data type
Input Network Dataset
The network dataset to be built.
Network Dataset Layer
Force Full Build
(Optional)
Specifies whether the full network will be built or only the parts of the network in dirty areas.
  • Checked—The full network will be built.
  • Unchecked—Only the parts of the network that have been changed since the last build will be built. This is the default.
Boolean
Derived output
Updated Input Network Dataset
The updated network dataset.
Environments
Current Workspace
Licensing information
  • Basic: Requires Network Analyst
  • Standard: Requires Network Analyst
  • Advanced: Requires Network Analyst
