Populate Alternate ID Fields (Network Analyst Tools)
Summary
Creates and populates additional fields on the turn feature classes that reference the edges in the network by alternate IDs. The alternate IDs help maintain the integrity of the turn features if the edge sources are edited in such a way that their ObjectID values change.
Usage
The
Edge#FIDfields in a turn feature class refer to the ObjectID of the line feature in an edge source in the network. However, ObjectIDs are system managed and can change during certain editing operations. To ensure that the turn features retain the correct reference to the edge features after this type of editing workflow, use the following workflow:Create and populate a unique ID field in each of the network's edge source feature class. Alternatively, use a unique ID field included in the data by the data provider, if one exists.
Run the Populate Alternate ID Fields tool to create and populate a set of alternate ID fields (
AltID#) in the network dataset's turn feature classes. The tool populates the alternate ID fields with the designated unique ID field values from the edge sources, linking each turn feature to the appropriate edge source feature through the alternate ID fields in addition to theEdge#FIDfields.Perform the edit operations that may change the ObjectIDs of the edge sources.
Run the Update By Alternate ID Fields tool to update the
Edge#FIDfields in the turn feature classes using the alternate ID field values to look up the ObjectID values of the corresponding edge source features.
The tool creates and populates new
AltID#fields in which # is the maximum number of edges per turn. For example, for turn feature classes that support turns of up to three edges, the tool creates and populates theAltID1,AltID2, andAltID3fields.
Parameters
| Label | Explanation | Data type |
Input Network Dataset |
The network dataset whose turn feature classes will receive alternate ID fields. The fields will be created on all of the turn feature classes added as a turn source to the network dataset. |
Network Dataset Layer |
Alternate ID Field Name |
The name of the alternate ID field on the edge feature sources of the network dataset. All edge feature sources referenced by turns must have the same name for the alternate ID field. |
String |
Derived output
Updated Input Network Dataset |
The updated network dataset. |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
