Update Analysis Layer Attribute Parameter (Network Analyst Tools)
Summary
Updates the network attribute parameter value for a network analysis layer. The tool should be used to update the value of an attribute parameter for a network analysis layer prior to solving with the Solve tool. This ensures that the solve operation uses the specified value of the attribute parameter to produce appropriate results.
Legacy:
This is a deprecated tool. Instead of updating your network analysis layer's attribute parameter values individually at analysis time, you should instead set attribute parameter values in advance by configuring travel modes on your network data source. At analysis time, simply choose the correct travel mode.
Usage
Parameterized network attributes are used to model some dynamic aspect of an attribute's value. For example, a tunnel with a height restriction of 12 feet can be modeled using a parameter. In this case, the vehicle's height in feet should be specified as the parameter value. This restriction will then evaluate to true if the vehicle is higher than 12 feet. Similarly, a bridge could have a parameter to specify a weight restriction.
This tool should only be used with network analysis layers having network attributes with parameters defined on them.
This tool can be used to repeatedly change the value of an existing parameter before solving a network analysis layer.
Parameters
| Label | Explanation | Data type |
Input Network Analysis Layer |
Network analysis layer for which the attribute parameter value will be updated. |
Network Analyst Layer |
Attribute |
The network attribute whose attribute parameter will be updated. |
String |
Parameter |
The parameter of the network attribute that will be updated. The parameters of type Object cannot be updated using the tool. |
String |
Value (Optional) |
The value that will be set for the attribute parameter. It can be a string, number, date, or Boolean (True, False). If the value is not specified, then the attribute parameter value is set to Null. If the attribute parameter has a restriction usage type, the value can be specified as a string keyword or a numeric value. The string keyword or the numeric value determines whether the restriction attribute prohibits, avoids, or prefers the network elements it is associated with. Furthermore, the degree to which network elements are avoided or preferred can be defined by choosing HIGH, MEDIUM, or LOW keywords. The following keywords are supported:
Numeric values that are greater than one cause restricted elements to be avoided; the larger the number, the more the elements are avoided. Numeric values between zero and one cause restricted elements to be preferred; the smaller the number, the more restricted elements are preferred. Negative numbers prohibit restricted elements. Tip:If the parameter value holds an array, separate the items in the array with the localized separator character. For example, in the U.S., you would most likely use the comma character to separate the items. So representing an array of three numbers might look like the following: "5,10,15". |
String |
Derived output
Updated Input Network Analysis Layer |
The updated network analysis layer. |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
