Apply Geo Positions Layout (Network Diagram Tools)
Summary
Moves each diagram junction and edge feature so they match the geographical positions of the associated network features.
Caution:
If you have an open edit session, you must save your edits prior to running this tool. This ensures that the diagram reflects the latest changes made to the network topology in the database. If you fail to save your edits, the edits will not be reflected in the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Each layout algorithm includes default parameter values. The default parameter values will be used unless otherwise specified. If the input network diagram is based on a template for which this layout has been configured with a different parameter value, that value will be used instead.
Usage
  • This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
  • The input network diagram layer must be from either a utility network or a trace network in a file or mobile geodatabase. or a network diagram service.
  • This layout algorithm moves each diagram junction and edge feature to match the geographical positions of the associated network features in the map view.
  • Reduced edges, which are network diagram-specific features, are displayed as straight lines between the junctions they connect.
  • Consider applying the layout in asynchronous mode on the server when working on very large diagrams.
Parameters
Label Explanation Data type
Input Network Diagram Layer
The network diagram to which the layout will be applied.
Diagram Layer
Restore edges geographic positions
(Optional)
Indicates whether or not diagram edges will be restored to the geographic position of their vertices:
  • Checked—Vertices along diagram edges will be restored when possible, moving them to match the geographic positions of the network features. This is the default.
  • Unchecked—Vertices along diagram edges will not be restored. They will appear as straight lines between their connecting junctions.
Boolean
Run in asynchronous mode on the server
(Optional)
Specifies whether the layout algorithm will run asynchronously or synchronously on the server.
  • Checked—The layout algorithm will run asynchronously on the server. This option dedicates server resources to run the layout algorithm with a longer time-out. Running asynchronously is recommended for layouts that are time consuming and may exceed the server time-out (for example, Partial Overlapping Edges) and applying to large diagrams (more than 25,000 features).
  • Unchecked—The layout algorithm will run synchronously on the server. It can fail without completion if it exceeds the service default time-out value of 600 seconds. This is the default.
Boolean
Derived output
Output Network Diagram
The updated network diagram layer.
Diagram Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
