Apply Template Layouts (Network Diagram Tools)
Summary
Applies the list of layout algorithms currently configured for the diagram template to the input network diagram layer.
Caution:
If you have an open edit session, you must save your edits prior to running this tool. This ensures that the diagram reflects the latest changes made to the network topology in the database. If you fail to save your edits, the edits will not be reflected in the diagram.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Usage
  • This tool is not supported when working with a database connection to a utility network or trace network in an enterprise geodatabase. You must use either the related published utility network or trace network service, or a utility network or trace network in a file or mobile geodatabase.
  • The input network diagram layer must be from either a utility network or a trace network in a file or mobile geodatabase. or a network diagram service.
  • This layout algorithm is useful when a diagram has been edited and you want to restore the layout to its original state. It reruns the list of automatic layout algorithms currently configured on the template on which the input network diagram is based. Depending on whether the template includes Diagram Feature Selection To Layout tasks, the layout algorithms apply to the only specified diagram feature selections or to the entire diagram content.
    Diagram templates support Diagram Feature Selection To Layout tasks starting with ArcGIS Enterprise 12.0 and ArcGIS Pro 3.6.
  • In some situations, the resulting layout can be similar to the one obtained when the diagram was generated. It will never be exactly the same because the new geometry for the diagram elements is computed based on the current geometry of the diagram elements, not the initial geographic geometry from diagram generation.
    There are some situations in which the resulting diagram layout will be completely different from the one at generation. For example, the template is configured to run an algorithm that preserves the geographical positions of the network features (for example, Square Edges or Partial Overlapping Edges). If you completely overwrite those positions by manually running a tree layout—Smart Tree, Main Line Tree, or Radial Tree—for the diagram, the layout will be quite different after running Apply Template Layouts.
Parameters
Label Explanation Data type
Input Network Diagram Layer
The network diagram to which the layout will be applied.
Diagram Layer
Derived output
Output Network Diagram
The updated network diagram layer.
Diagram Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
