Export Diagram Content (Network Diagram Tools)
Summary
Exports diagram content in a simple format (JSON) that reflects basic connectivity. Additional optional information such as diagram properties, diagram feature geometry, network element attributes, and aggregated elements can also be exported.
The input network or diagram layer can be from a utility network or trace network in a file or mobile geodatabase, a utility network service, a trace network service, or a database connection to a utility network or trace network in an enterprise geodatabase.
License:
The active portal account must be assigned a license with the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Learn more about exporting diagram content
Usage
  • The exported .json file can be used for network calculation and analysis or to feed external systems.
    Learn more about the output JSON response syntax
  • When exporting diagram content with attributes, attributes with coded domain values can be exported as either raw values or string descriptions.
Parameters
Label Explanation Data type
Input Network or Network Diagram Layer
The utility network or trace network layer, utility network or trace network data element, or network diagram layer related to the network diagram to export.
Utility Network; Trace Network; Utility Network Layer; Trace Network Layer; Diagram Layer
Network Diagram Name
The name of the network diagram to export.
String
Output File
The output .json file that will be created with the exported diagram content.
File
Include diagram properties
(Optional)
Specifies whether the diagram properties will be exported.
  • Checked—The diagram properties (statistics, creation and update dates, and so on) will be exported.
  • Unchecked—The diagram properties will not be exported. This is the default.
Boolean
Include geometries
(Optional)
Specifies whether the geometry of the diagram features will be exported.
  • Checked—Each diagram feature will be exported with its geometry.
  • Unchecked—Each diagram feature will be exported without its geometry. This is the default.
Boolean
Include attributes
(Optional)
Specifies whether the attributes of the associated network elements will be exported.
  • Checked—The associated network element attributes will be exported.
  • Unchecked—The associated network element attributes will not be exported. This is the default.
Boolean
Include aggregations
(Optional)
Specifies whether each diagram feature will be exported with a list of network elements it aggregates.
  • Checked—Each diagram feature will be exported with a list of network elements it aggregates with their asset group and asset type values.
  • Unchecked—The diagram feature aggregations will not be exported. This is the default.
Boolean
Use domain and subtype descriptions
(Optional)
Specifies how coded domain and subtype values will be exported. This parameter is only enabled when the Include attributes or Include aggregations parameters are checked.
  • Checked—Coded domain and subtype values will be exported using their string descriptions rather than raw values.
  • Unchecked—Coded domain and subtype values will be exported as raw values. This is the default.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
