Make Diagram Layer (Network Diagram Tools)
Summary
Creates a network diagram layer from a network diagram.
Usage
  • The output diagram layer can be used as input to geoprocessing tools that accept a diagram layer as input, including the Store Diagram, Update Diagram, and Apply Smart Tree Layout tools.
  • This tool must be run in ModelBuilder or Python scripts before running any tool that requires a diagram layer.
Parameters
Label Explanation Data type
Input Network
The utility network or trace network the diagram is related to.
Utility Network; Trace Network; Utility Network Layer; Trace Network Layer
Network Diagram Name
The network diagram name.
String
Output Layer
The name of the diagram layer that will be created.
Diagram Layer; Group Layer
Make a group layer containing the feature layers
(Optional)
Specifies the type of output layer that will be created.
  • Checked—The output will be a group layer with sublayers. The feature sublayers can be exported to geodatabase feature classes using the Feature Class To Geodatabase tool.
  • Unchecked—The output will be a diagram layer without a sublayer. Diagram layers without a sublayer can be used as input to geoprocessing tools such as the Store Diagram, Update Diagram, and Apply Smart Tree Layout tools. This is the default.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
