An overview of the Hydrology toolset
The Hydrology toolset contains tools that use elevation data and ancillary information to model the movement of water across the landscape for delineating watersheds and tracing downstream flow path.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Tool
Trace Downstream
Determines the path water will take from a particular location to its furthest downhill path.
Watershed
Determines the contributing area above each input point. A watershed is the upslope area that contributes flow.
Tools in the Hydrology toolset
