Extract Data Task (Server Tools)
Summary
Extracts the selected layers in the specified area of interest to the selected formats and spatial reference, and returns the data in a .zip file.
Caution:
This tool is intended primarily for use as part of a geoprocessing service. When using this tool as part of a geoprocessing service, copy the tool into a custom toolbox, and edit the model if necessary. Because the geoprocessing service wizard is not available in ArcGIS Desktop, you must save the contained toolbox as a supported previous version and publish it from ArcGIS Desktop of the same version of the toolbox. After publishing, you can connect to the server and use the service from ArcGIS Desktop.
Usage
- The Feature Format and Raster Format parameters contain a list of options. These options are set from the Value List filter on the Parameters tab of the model Properties.
Parameters
| Label | Explanation | Data type |
Layers to Clip |
The layers to be clipped. Layers must be feature or raster; layer files are not supported. |
Layer |
Area of Interest |
One or more polygons by which the layers will be clipped. |
Feature Set |
Feature Format |
Specifies the format of the output features. The format should be specified as follows:
The hyphens are required and there must be one space before and after the hyphen. For example:
The list of short names supported includes |
String |
Raster Format |
Specifies the format of the output raster datasets. The format should be specified as follows:
Some of the above raster formats have limitations and not all data can be converted to the format. |
String |
Output Zip File |
The zip file that will contain the extracted data. |
File |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
