Extract Data (Server Tools)
Summary
Extracts selected layers in the specified area of interest to a specified format and spatial reference. The extracted data is then written to a .zip file.
Caution:
This tool is intended primarily for use as part of a geoprocessing service. When using this tool as part of a geoprocessing service, copy the tool into a custom toolbox, edit the model, and reconfigure it as necessary. Because the geoprocessing service wizard is not available in ArcGIS Desktop, you must save the contained toolbox as any supported previous version, and publish it from ArcGIS Desktop of the same version of the toolbox. After publishing, you can connect to the server and use the service from ArcGIS Desktop.
Usage
  • A custom spatial reference name can be provided for the Spatial Reference parameter when the folder containing the custom spatial reference is specified in the Custom Spatial Reference Folder parameter.
Parameters
Label Explanation Data type
Layers to Clip
The layers to be clipped. Layers must be feature or raster; layer files are not supported.
Layer
Area of Interest
One or more polygons by which the layers will be clipped.
Feature Set
Feature Format
Specifies the format of the output features. The format should be specified as follows:
  • Name or format - Short Name - extension (if any)
The hyphens are required and there must be one space before and after the hyphen.
For example:
  • File Geodatabase - GDB - .gdb
  • Shapefile - SHP - .shp
  • Autodesk AutoCAD - DXF_R2007 - .dxf
  • Autodesk AutoCAD - DWG_R2007 - .dwg
  • Bentley Microstation Design (V8) - DGN_V8 - .dgn
The list of short names supported includes DGN_V8, DWG_R14, DWG_R2000, DWG_R2004, DWG_R2005, DWG_R2007, DWG_R2010, DXF_R14, DXF_R2000, DXF_R2004, DXF_R2005, DXF_R2007, and DXF_R2010.
String
Raster Format
Specifies the format of the output raster datasets. The format should be specified as follows:
  • Name of format - Short Name - extension (if any)
For example:
  • Esri GRID - GRID
  • ERDAS IMAGINE - IMG - .img
  • Tagged Image File Format - TIFF - .tif
  • Joint Photographics Experts Group - JPEG - .jp2
Some of the above raster formats have limitations and not all data can be converted to the format.
String
Spatial Reference
The spatial reference of the output data delivered by the tool.
For standard Esri spatial references, the name you provide should be the name of the desired coordinate system. This name corresponds to the name of the spatial reference's projection file. Alternatively, you can use the well-known ID (WKID) of the coordinate system.
The following are examples:
  • Sinusoidal (world)
  • WGS 1984 World Mercator
  • NAD 1983 HARN StatePlane Oregon North FIPS 3601 (Meters)
  • WGS 1984 UTM Zone 11N
  • 102003
  • 54001
  • If you want the output to have the same coordinate system as the input, use the Same As Input option.
For a custom projection, the name provided should be the name of the custom projection file (without the extension). The location of the custom projection files should be specified in the Custom Spatial Reference Folder parameter.
  • Same As Input—The input coordinate system will be used.
String
(Optional)
The location of any custom projection file or files referenced in the spatial reference parameter. This is only necessary if the custom projection file is not in the default installation coordinate system folder.
Folder
Output Zip File
The zip file that will contain the extracted data.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
