Flow Length (Spatial Analyst Tools)
Summary
Calculates the upstream or downstream distance, or weighted distance, along the flow path for each cell.
Usage
  • A primary use of the Flow Length tool is to calculate the length of the longest flow path within a given basin. This measure is often used to calculate the time of concentration of a basin. This would be done using the Upstream option.
    The tool can also be used to create distance-area diagrams of hypothetical rainfall and runoff events using the weight raster as an impedance to movement downslope.
  • The value type for the Flow Length output raster is floating point.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input flow direction raster
The input raster that shows the direction of flow out of each cell.
The flow direction raster can be created using the Flow Direction tool.
Raster Layer
Direction of measurement
(Optional)
The direction of measurement along the flow path.
  • Downstream—Calculates the downslope distance along the flow path, from each cell to a sink or outlet on the edge of the raster.
  • Upstream—Calculates the longest upslope distance along the flow path, from each cell to the top of the drainage divide.
String
Input weight raster
(Optional)
An input raster for applying a weight to each cell.
If no weight raster is specified, a default weight of 1 will be applied to each cell. For each cell in the output raster, the result will be the number of cells that flow into it.
Raster Layer
Return value
Output raster
The output raster that shows for each cell the upstream or downstream distance along a flow path.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Current Workspace, Extent, Geographic Transformations, Output CONFIG Keyword, Output Coordinate System, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
