How Cut Fill works
Available with the Spatial Analyst license.
Available with the 3D Analyst license.
A cut-and-fill operation is a procedure in which the elevation of a landform surface is modified by the removal or addition of surface material.
The Cut Fill tool summarizes the areas and volumes of change from a cut-and-fill operation. By taking surfaces of a given location at two different time periods, it identifies regions of surface material removal, surface material addition, and areas where the surface has not changed.
Applications
With the Cut Fill tool, you can do the following:
Identify regions of sediment erosion and deposition in a river valley.
Calculate the volumes and areas of surface material to be removed and areas to be filled to level a site for building construction.
Identify areas that become frequently inundated with surface material during a mudslide in a study to locate safe areas of stable land for building homes.
Display
When the Cut Fill tool is run, by default, a specialized renderer is applied to it that highlights the locations of cut and of fill. The determinant is the attribute table of the output raster and considers positive volume to be where material was cut (removed) and negative volume where material was filled (added).
See the illustration in the tool documentation for an example.
Using Cut Fill for river morphology
Using river morphology as an example to track the amount and location of erosion and deposition in a river valley, a series of cross sections need to be taken through the valley and surveyed on a regular basis to identify regions of sediment erosion and deposition.
The following graphics show a side profile of one of the cross-sections in the surface that has experienced changes where material has been removed from some areas and added to others.
The first graphic shows the surface in its original state:
The second graphic shows the surface after a period of time where erosional and depositional forces have acted on it:
The third graphic shows how the Cut Fill tool identifies the areas where material has been removed (cut) and where it has been gained (filled):
Calculations
The output raster retains several properties of the change in its attribute table.
Edge-connected areas identified
First, from the upper-right corner, a sequential value is given to each unique edge-connected area of cut, fill, or no change.
Different types of connectivity are demonstrated in the following graphic:
Volume calculation
For each of the cut/fill regions, the volume is calculated. For a single cell, the formula for the volume is:
\(Vol = (cell\_area) * ΔZ\)
where:
\(ΔZ = Z_{Before} - Z_{After}\)
For example, a particular cell has an initial z-value of 235 and a cell size of 10 meters. If the location is excavated by 3 metres, the volume will be:
From the formula, in areas where material has been cut, the volume will be positive (larger value - smaller value > 0). When material was added, the volume will be negative (smaller value - larger value < 0).
Area calculation
For each of the cut/fill regions, the area is also calculated. This is simply the number of cells in the region (Count) multiplied by the cell area of the raster.
Attribute table
An example of the attribute table for the output raster is the following:
ObjectID Value Count Volume Area
0 1 55819 0.000 258107056
1 2 707 -137415060.250 3269168
2 3 65 -114913516.625 300560
3 4 810 1235057106.000 3745440
Positive values for volume indicate areas that have had material cut (removed), and negative volume values are for areas that have had material filled (added).
