How Darcy Flow and Darcy Velocity work
Available with Spatial Analyst license.
The Darcy Flow and Darcy Velocity tools, in conjunction with Particle Track and Porous Puff tools, can be used to perform rudimentary advection–dispersion modeling of constituents in groundwater. This methodology models two-dimensional, vertically mixed, horizontal, and steady state flow, where head is independent of depth.
Darcian flow calculations
The equations used in the calculation of Darcian flow are detailed in the following sections.
Calculating flow and velocity
Darcy's Law states that the Darcy velocity q in a porous medium is calculated from the hydraulic conductivity K and the head gradient \(\nabla \textnormal{h}\) (the change in head per unit length in the direction of flow in an isotropic aquifer) as:
q = -K \(\nabla h\)
  • where K may be calculated from the transmissivity T and thickness b as K = T/b.
This q, with units of volume/time/area, is also known as the specific discharge, the volumetric flux, or the filtration velocity. Bear (1979) defines it as the volume of water flowing per unit time through a unit cross-sectional area normal to the direction of flow.
Closely related to this volumetric flux is the aquifer flux U, which is the discharge per unit width of the aquifer (with units of volume/time/length):
U = -T \(\nabla \textnormal{h}\)
This construction assumes that the head is independent of depth so that flow is horizontal.
The average fluid velocity within the pores, called the seepage velocity V, is the Darcy velocity divided by the effective porosity of the medium:
Formula for seepage velocity (V)
In the Darcy Flow implementation, it is this seepage velocity V that is calculated on a cell-by-cell basis. For cell i,j, the aquifer flux U is calculated through each of the four cell walls, using the difference in heads between the two adjacent cells and the harmonic average of the transmissivities Ti+1/2,j (Konikow and Bredehoeft, 1978), which are assumed to be isotropic.
For example, for the x component of \(\nabla \textnormal{h}\), the equation between cells i,j and i+1,j would be:
δh/δx ≈ (hi+1 - hi) / Δx
This scheme is illustrated in the following graphics.
Illustration of seepage velocity (V) calculated on a cell-by-cell basis
Calculating residual volume
In the cell wall calculation that follows, the aquifer flux between cell i,j and cell i+1,j flows parallel to the x direction and is calculated as:
Formula for aquifer flux flowing parallel to the x direction
To determine a groundwater volume balance, the groundwater discharge through the cell wall must be calculated. This discharge Qx(i+1/2) is calculated from the aquifer flux U and the width of the cell wall Δy by:
Qx(i+1/2,j) = Ux(i+1/2,j) Δy
Similar values are obtained for all four cell walls. These values are used to calculate the groundwater volume balance residual Rvol for the cell, which is written to the output raster. This value represents the surplus (or, in the case of a negative number, the deficit) of water in each cell given the net flow into the cell, calculated as:
Formula for volume balance residual Rvol
This residual Rvol should ideally be zero for all cells. When examining the output raster containing the residuals, look for deviations from zero. Large positive or negative residuals indicate a production or loss of mass, which violates the principle of continuity and suggests inconsistent head and transmissivity data. Consistent patterns of positive or negative residuals suggest that unidentified sources or sinks are present. Reduce the residuals before any further modeling. Typically, adjustments are made to the transmissivity field to reduce the residuals.
Calculating flow vectors
The actual equations used in Darcy Flow for calculating the flow vectors for each cell are condensed from the arithmetic average of Ux(i-1/2,j) and Ux(i+1/2,j), divided by the center cell's porosity ni,j and thickness bi,j to give a value for the seepage velocity Vx at the center:
Formula for seepage velocity Vx
and a similar equation is used to calculate Vy at the center:
Formula for seepage velocity Vy
This centering is done to conform to the convention that stored values represent values at the center of the cell. These values are converted to direction and magnitude in geographic coordinates for storage in the output direction and magnitude rasters.
In the case of the bounding cells of the raster in which the information is incomplete, values for velocity are simply copied from the nearest interior cell.
Porosity values
The following tables summarize some values for porosity and hydraulic conductivity for a variety of geologic media.
Table 1: Hydraulic conductivities of unconsolidated media
Medium
K (m/s)
Coarse gravel
10-1 - 10-2
Sand and gravel
10-1 - 10-5
Fine sand, silts, loess
10-5 - 10-9
Clay, shale, glacial till
10-9 - 10-13
Hydraulic conductivities of consolidated media, Marsily (1986).
Table 2: Hydraulic conductivities of consolidated media
Medium
K (m/s)
Dolomitic limestone
10-3 - 10-5
Weathered chalk
10-3 - 10-5
Unweathered chalk
10-6 - 10-9
Limestone
10-5 - 10-9
Sandstone
10-4 - 10-10
Granite, gneiss, compact basalt
10-9 - 10-13
Table 3: Porosities of geologic media
Medium
Total porosity
Unaltered granite and gneiss
0.0002 - 0.018
Quartzite
0.008
Shale, slate, mica schist
0.005 - 0.075
Limestone, primary dolomite
0.005 - 0.125
Secondary dolomite
0.10 - 0.30
Chalk
0.08 - 0.37
Sandstone
0.035 - 0.38
Volcanic tuff
0.30 - 0.40
Sand
0.15 - 0.48
Clay
0.44 - 0.53
Swelling clay, silt
up to 0.90
Tilled arable soil
0.45 - 0.65
Porosities of geologic media, Marsily (1986).
Additional tabulated values for porosity and hydraulic conductivity are provided in Freeze and Cherry (1979). Gelhar et al. (1992) present a summary of porosity and transmissivity of various specific formations reported in the literature. A detailed discussion of porosity in sedimentary materials appears in Blatt et al. (1980). A complete discussion of advection–dispersion modeling using these functions is presented in Tauxe (1994).
Examples
The typical sequence for groundwater dispersion modeling is to perform Darcy Flow, then Particle Track, then Porous Puff.
An example of the settings to make in the tool dialog box for Darcy Flow follows:
Input groundwater head raster : head
Input effective formation porosity raster : poros
Input saturated thickness raster : thickn
Input formation transmissivity raster : transm
Output groundwater volume balance raster : resid1
Output direction raster : dir1
Output magnitude raster : mag1
An example of the settings to make in the tool dialog box for Darcy Velocity follows:
References
Bear, J. Hydraulics of Groundwater. McGraw-Hill. 1979
Blatt, H., G. Middleton, and R. Murray. Origin of Sedimentary Rocks, 2nd Ed. Prentice-Hall. 1980
Freeze, R. A., and J. A. Cherry. Groundwater. Prentice-Hall. 1979
Gelhar, L. W., C. Welty, and K. R. Rehfeldt. "A Critical Review of Data on Field-Scale Dispersion in Aquifers". Water Resources Research, 28 no. 7: 1955-1974. 1992.
Konikow, L. F. and J. D. Bredehoeft. "Computer Model of Two-Dimensional Solute Transport and Dispersion in Ground Water", USGS Techniques of Water Resources Investigations, Book 7, Chap. C2, U.S. Geological Survey, Washington, D.C. 1978.
Marsily, G. de. Quantitative Hydrogeology. Academic Press. 1986.
Tauxe, J. D. "Porous Medium Advection-Dispersion Modeling in a Geographic Information System". Doctoral Dissertation in Civil Engineering. The University of Texas at Austin, 1994.
