Add Territory Barriers (Territory Design Tools)
Summary
Allows the addition of polygon or line features to prevent or restrict the growth of territories.
Illustration
Line barriers
Usage
  • Line or polygon layers can be used as barriers.
  • New features can be added to an existing barrier.
  • Each level can contain both an impedance and a restricted area.
Parameters
Label Explanation Data type
Input Territory Solution
The Territory Design solution layer that will be used in the analysis.
Group Layer; Feature Dataset; String
Level
The level to which the barriers will be applied.
String
Input Barrier Features
Line or polygon features used as a barrier.
Feature Layer
Barrier Type
(Optional)
Specifies the type of barrier.
  • Impedance—Limits the growth of territories. This is the default.
  • Restricted Area—Prevents the creation of territories.
String
Append to existing barriers
(Optional)
Specifies whether to append or replace the records to the barriers layer.
  • Checked—Appends records to an existing barrier layer.
  • Unchecked—Creates a new barrier layer or replaces records in an existing barrier layer. This is the default.
Boolean
Derived output
Updated Territory Solution
The updated territory solution.
Group Layer
Environments
Current Workspace
Licensing information
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
