Add Territory Level (Territory Design Tools)
Summary
Creates a new empty feature class to represent a level.
Usage
  • Specify an existing territory solution.
  • A new level is created above the base level. Base features are aggregated to the new level.
  • The %Number% variable determines where the integer number is placed, either after or before the territory name—for example, Territory %Number% produces Territory 1, Territory 2, and so forth, and %Number% Territory produces 1 Territory, 2 Territory, and so forth.
  • The default primary feature class for a base level with polygon features is Base Boundaries.
  • The default primary feature class for a base level with point features is Base Centers.
Parameters
Label Explanation Data type
Input Territory Solution
The input territory solution.
Group Layer; Feature Dataset; String
Level Name
The name of the new territory level.
String
Default Territory Name
(Optional)
The name to be used as a prefix for new territories that will be created.
String
Primary Feature Class
(Optional)
Specifies the class level that will be used for storing level attributes.
  • Territory Boundaries—Polygon features that represent the territory boundaries.
  • Territory Centers—Point features that represent the territory centers.
  • Base Boundaries—Polygon features that represent the base-level feature boundaries.
  • Base Centers—Point features that represent the base-level feature centers.
String
Derived output
Updated Territory Solution
The updated territory solution.
Group Layer
Environments
Current Workspace
Licensing information
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
