Create Territory Solution (Territory Design Tools)
Summary
Creates a new territory solution with two levels and loads input features into the base level.
Usage
Input features for the base level can be a point feature layer or a polygon feature layer.
The type of input layer will determine how the base level is displayed, for example, points or polygons.
Additional geometries can be created to display either boundary centers or polygon boundaries.
Additional layers can be created to display the base level, for example, centers of polygons or boundaries of points.
The ID Field and the Name Field parameters are optional. Specifying these parameters will load attribute values from the input features to uniquely identify features in the base layer, such as ZIP Codes or census tract names. If no ID field is specified, a unique ID will be automatically generated.
By default, all of the fields in the input layer will be added to the territory solution. You can turn off field visibility by right-clicking the column header and clicking Hide Field if you do not want the field to be added to the territory solution.
The
%Number%variable determines where the integer number is placed, either after or before the territory name—for example, Territory%Number%produces Territory 1, Territory 2, and so forth, and%Number%Territory produces 1 Territory, 2 Territory, and so forth.A mask layer is only supported for a point-based territory solution.
Parameters
| Label | Explanation | Data type |
Input Features |
The geometry or data features that will be used as the base level of the created solution. The level will have the same name as the input features. |
Feature Layer |
Territory Solution Name |
The name of the territory solution that will be created. |
String |
ID Field (Optional) |
The field that contains ID values for objects in the level. |
Field |
Name Field (Optional) |
The input layer field that contains the name values that will be loaded into the base level. |
Field |
Territory Level Name (Optional) |
The name of the territory level, for example, level 2. |
String |
Default Territory Name (Optional) |
The prefix for the names of the new territories that will be created, for example, Territory 1, Territory 2, and Territory 3 or District 1, District 2, and District 3. |
String |
Boundary Mask (Optional) |
The layer that will be used as a mask to limit the growth of point-based layers. |
Feature Layer |
Derived output
Output Territory Solution |
The output territory solution. |
Group Layer |
Environments
Licensing information
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
