Load Territory Records (Territory Design Tools)
Summary
Adds records (features) or updates existing records for the specified level.
Usage
  • The tool specifies an existing territory solution.
  • The tool specifies the level where records will be added.
  • A point layer will add records to the Territories Centers layer.
  • A polygon layer will add records to the Territories Boundary layer.
  • The tool requires a feature layer or table for input.
Parameters
Label Explanation Data type
Input Territory Solution
The name of the input territory solution.
Group Layer; Feature Dataset; String
Level
The name of the level to which the data will be loaded.
String
Input Data
The layer or records to be loaded.
Table View
ID Field
(Optional)
The field containing the ID values to be loaded into the level.
Field
Name Field
(Optional)
The field containing the name values to be loaded into the level.
Field
Field Map
(Optional)
The values that will be used for the territory properties.
Value table columns:
  • Attribute—The attributes that will be used for the territory properties.
    • Parent Territory ID—The ID of the parent territory.
    • Locked State—The territory can't be modified.
    • Center Locked—Center points can't be modified and will remain in their fixed locations.
  • Field—The fields that will be used for the territory properties.
Value Table
Append Data
(Optional)
Specifies whether the records being loaded will be appended or replaced.
  • Checked—The records being loaded to the specified level will be appended.
  • Unchecked—The records being loaded to the specified level will be replaced. This is the default.
Boolean
Derived output
Updated Territory Solution
The updated territory solution.
Group Layer
Environments
Current Workspace
Licensing information
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
