Rebuild Territory Solution (Territory Design Tools)
Summary
Updates the territory solution to reflect changes made to the base level.
Usage
The input data must be an existing territory solution layer.
Territory levels are rebuilt with the correct territory ID.
If the parent ID is updated in the base level attribute table, the territory level is not automatically updated to reflect the changes. You must rebuild to propagate the changes to the upper level.
The following changes are supported by the tool:
Edits to the geometry of the base layer, for example, add, move, and delete.
Updates to attribute value; for example, attribute values will be aggregated to the upper level with rebuild.
Updates to parent ID.
Removing fields is not supported.
If territories are manually updated using the Territory Design ribbon tools—for example, Assign and Unassign—the upper level territory will automatically update and you will not need to rebuild.
Parameters
| Label | Explanation | Data type |
Input Territory Solution |
The input territory solution. |
Group Layer; Feature Dataset; String |
Boundary Mask (Optional) |
The layer that is used as a mask to limit the growth of point-based layers. |
Feature Layer |
Derived output
Updated Territory Solution |
The updated territory solution. |
Group Layer |
Environments
Licensing information
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
