Validate Territories (Territory Design Tools)
Summary
Validates a territory solution for invalid territories.
Usage
Run this tool after manually editing the territory solution. Any violations will need to be reviewed and resolved manually.
Validation issues will be included in the tool messages and added to the
Territory Validation Errorsfield orFeature Validation Errorsfield.Territory validation issues will be displayed in the
Territory Validation Errorsfield.The
Feature Validation Errorsfield will display features that contain validation issues for a territory.The tool will analyze the territory solution for the following errors:
Barriers violation
Buffer distance constraint violation
Minimum attribute constraint limit violation
Maximum attribute constraint limit violation
Minimum distance between centers constraint violation
Maximum territory radius constraint violation
Territory is empty
Territory center is undefined
Territory is not contiguous
Territory has holes
Territory name is not unique
Parameters
| Label | Explanation | Data type |
Input Territory Solution |
The territory solution that will be validated. |
Group Layer; Feature Dataset; String |
Level |
The level that will be analyzed in the validation. |
String |
Derived output
Updated Territory Solution |
The territory solution output. |
Group Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
