000210: Cannot create output <value>.
The output could not be created. This error may occur for a number of reasons, including the following:
  • The output is locked and could not be overwritten.
  • You do not have permissions to write or update the data.
  • The output path is invalid. The path may include a typo or the dataset name might be invalid for the workspace.
  • There is insufficient storage space to create the output.
  • The input has a field type that is not supported by the output.
Solution
Confirm that the data is not locked by another user or application and that you have full rights to the workspace being used. If your workspace has an active edit session, you must stop editing before you can delete or overwrite a dataset in the workspace. Ensure that the path to the data is correct (check for typos in the folder path). Check that there is sufficient space to write the output. Confirm that the input does not have any field types that are unsupported by the output.
If none of the above help, attempt to create the output in a new location.
