000260: Failed to copy <value> into <value>.
While using the Copy tool, the input could not be successfully copied to its new location.
The in_memory and memory workspaces are not supported as an output location.
Solution
Confirm that the output location is valid, you have permissions to write to the output location, and it does not contain any files that will interfere with a successful copy operation.
If the input data has attachments, ensure you have a license that supports attachment copying.
