000381: <value> is non-editable.
The tool will alter the original input dataset. If the data format is not editable, the tool will fail. For example, running the Integrate tool on an SDC feature class will cause this error as it is a read-only format.
Solution
To integrate the data, consider using the Export Features tool to convert the dataset to an editable format, such as a geodatabase feature class or shapefile, and use that as input.
