000407: No fields selected in <value>.
Select at least one of the fields from the list.
Solution
If you are using a tool dialog box, choose a field from the list of field names. If you are running a tool from a script or the command line, specify a field name, using a semicolon to separate multiple field names, if more than one field name is supported.
