000517: The coordinate system is not defined for the input dataset.
The tool can only be used when the input dataset has a coordinate system defined.
Solution
If the input dataset has an undefined (unknown) coordinate system, do one of the following:
  • Use the Define Projection tool to modify the input dataset before running this tool.
  • Use the Input Coordinate System parameter of the Project tool to specify the coordinate system of the input dataset.
