000536: Field <value> of input <value> will be truncated from <value> to 320 in length.
A coverage attribute table only supports a maximum width of 320 characters for a text field. The length of the output field has been truncated.
Solution
The field has been modified for the output. If required information is being lost in the output field, consider using the Calculate Field tool first to redefine how the field values are arranged, or use the Export Features tool and its optional field map parameter to create a temporary feature class that redefines the format of the field's values.
