000588: Invalid number of parameters. Should be <value> not <value>.
The number of parameters entered does not match the expected number.
Solution
Confirm that your syntax is valid. If you're using a complex parameter that includes spaces, enclose the parameter in quotation marks to ensure that the value is not interpreted as multiple parameter values.
