000592: Output format does not support BLOB, Raster, or GUID fields. Field(s) <value> will not be converted to output.
The output data format does not support one or more BLOB, raster, or GUID field types included in the input dataset. Shapefiles, for instance, do not support BLOB fields. Field types that are not supported by the output data format will not be transferred to the output.
Solution
If retaining the unsupported fields is necessary, use a geodatabase as output.
