000603: Error in setting <value> into <value>.
The environment cannot be set to the value specified. The value is inconsistent with what is expected by the environment. For instance, setting the XY Tolerance environment to Feet will result in this error.
Solution
Confirm that the value is appropriate for the environment you are using.
