000645: Output format does not support GlobalIDs. Field <value> will not be converted to output.
Since the output format does not support GlobalID fields, any GlobalID fields in the input will not be transferred to the output. Shapefiles, for instance, do not support GlobalID fields.
Solution
If retaining the GlobalID fields is necessary, change the output format to a geodatabase.
