000679: At least one layer has to be selected.
The layer list is empty or no layer in the layer list is selected while creating a multilayer cache.
Solution
Select at least one layer in the layer list before you generate, update, or delete the cache. If the layer list is empty, ensure that the map service is running and you can draw the service. Typically, the layer list is empty if the SOC machines cannot access the data referencing the layers in the map document.
