000747: Multigeneration replication not supported in this release of the geodatabase.
Two-way and one-way replicas are not supported in the release of the geodatabase you are connected to. This type of replication functionality is supported at ArcGIS 9.2 and later. If you receive this error, it means that a geodatabase you are connected to is from an earlier version.
Solution
You must use geodatabases with a minimum release version of 9.2.
