000812: The parameter value for the Field Map is invalid.
The syntax for the field map parameter value is invalid and cannot be parsed correctly.
Solution
Modify the syntax of the field map used: "fldName newFldName visible;fldName1 newFldName1 visible1;…;fldNameN newFldNameN visibleN". Refer to Mapping fields for more information about mapping fields in scripts. The FieldMappings object is a collection of field map objects, and is used as the parameter value for tools that perform field mapping.
