000851: Use the Spatial Autocorrelation (Moran's I) Tool to ensure residuals are not spatially autocorrelated.
Results from regression analysis are only dependable when the model and data meet the assumptions and limitations of that method. Statistically significant spatial autocorrelation in the regression residuals indicates misspecification (a missing key explanatory variable). Results are invalid when a model is misspecified.
Solution
Run the Spatial Autocorrelation (Moran's I) tool on the regression residuals in the output feature class. If the z-score indicates spatial autocorrelation is statistically significant, map the residuals and run a hot spot analysis on the residuals to see whether the spatial pattern of over and under predictions provides clues about missing key variables from the model. If you cannot identify the missing key variables, results of the regression are invalid and you should consider using a spatial regression method designed for spatial autocorrelation in the error term. When spatial autocorrelation in OLS residuals is due to nonstationary spatial processes, use the Geographically Weighted Regression tool instead of Ordinary Least Squares (OLS) tool.
