000856: An error was encountered while executing <value>.
There are several possible causes for this error, investigate different possibilities.
Solution
Do the following:
  • Confirm that the syntax is correct, the input datasets exist as specified and are valid, and that write access to the output location is available.
  • Ensure that the machine has sufficient resources to complete the process.
  • Review the documentation for any notes or usage tips that may apply.
  • Contact Esri Technical Support if the problem persists.
