000864: <value>: The input is not within the defined domain. <value>.
The specified input is not valid for the parameter. You may have used a value for the parameter that is not one of the defined options or is not a valid type or you made a typing error. The command syntax will identify the valid options for each function. For example, the options for the Filter type parameter are only LOW or HIGH. No other text string will be accepted.
Solution
Review the syntax and documentation to ensure you are specifying the command correctly and that the input types are valid.
