000869: <value>: The Z units of the output geographical spatial reference are undefined. A default Z factor of 1 was used.
Surface calculations in geographic coordinate systems may not create valid output results when the horizontal ground units and vertical elevation units use different measures. This typically occurs when the horizontal (x,y) units are geographic and the vertical (z) units are a linear unit (for example, feet or meters).
The tool could not determine an appropriate value for the z-factor because the z-coordinate unit is not defined. By default, a value of 1.0 will be used for the z-factor.
Since the length of a degree of longitude changes with latitude, you must specify an appropriate z-factor for that latitude.
Solution
Do one of the following:
  • If the default value of 1.0 is not acceptable, specify an appropriate z-factor for the parameter.
    If the output spatial reference contains the correct vertical coordinate system, an appropriate z-factor can be calculated.
  • Alternatively, use a projected coordinate system in which the x,y and z-units are the same.
  • Use the Define Projection tool or Project Raster tool to apply the proper vertical coordinate system to the input data.
