000941: Negative Weight values have been interpreted as zero for processing.
Some values in the weights field specified are less than zero. Negative weights cannot be processed; they have been processed as zero values for computation.
Solution
Investigate the negative values in the specified weight field to determine if interpreting them as zero is appropriate for your analysis.
