001002: Nonnumeric or negative entry in field encountered. set to 0.
One or more values in the Minimum Allowed Distance field were either nonnumeric or negative and could not be used as input. The parameter value is reset to 0 for the records with improper values.
Solution
Check the values in the Minimum Allowed Distance field of the Constraining Feature Class and fix or remove any nonnumeric or negative values.
