001026: Skipping feature <value> because the calculated coordinate system has an invalid parameter.
This warning occurs when a spatial reference with a bad projection parameter is calculated for one of the features and the feature is not updated. This can occur by setting a too large a value for Standard Parallel Offset—one where a parallel has gone past the north or south pole (this may easily happen at high latitudes).
Solution
Reduce the Standard Parallel Offset value.
