001030: Input folder should contain two or more images of the same supported image format.
To create a video, the input folder should contain two or more images of the same supported image formats (BMP or JPEG).
Solution
Make sure that the input folder has two or more images of the same supported image format. For example, if you select the Image Format to be BMP, make sure that there are two or more images of BMP format in the input folder.
