001089: Skipping <value> because not supported by SchemaOnly.
Data sources that do not support schema only will be skipped. If the Schema Only parameter is checked and the tool encounters a layer that is not supported for schema only, a warning message will be displayed and that layer will be skipped. If the only layer specified is unsupported for schema only, the tool will fail and no data will be consolidated.
Solution
Uncheck the Schema Only parameter, or rerun the tool without the offending layer.
