001092: You cannot use a dataset that was created with the 9.3 Grid Manager.
Due to feature class schema changes, a dataset that was created with the 9.3 Grid Manager cannot be used to save output grids from the Make Grids And Graticules Layer tool.
Solution
Do one of the following:
  • Create a new feature dataset in the geodatabase and save output grids in this dataset.
  • Use any existing dataset in a 9.3 (or later) geodatabase version that was not created using the 9.3 Grid Manager.
