001103: Error converting directory to short-name format.
On Windows operating systems, this tool always attempts to convert folder paths to short-name (8.3 compliant) format. Because of the conversion, you don't typically need to specify paths in the short-name format. This error indicates that something happened to prevent the conversion from succeeding.
Solution
Use 8.3-compliant paths for the parameters of this tool. Keep the total path length to fewer than 122 characters. Make sure that each folder name in the path is eight characters or less. Avoid using spaces and other special characters, such as a plus sign (+), an equal sign (=), and a left bracket ([).
