001158: Features with NULL field values (only includes first 30): <value> = <value>.
Some of the records in the dataset have null field values. These will be written to the output text file as NULL.
Solution
The NULL string may cause problems if you try to import the text file into an external software package in which a numeric value is expected. You may need to complete a global search and replace to change the NULL text string to a numeric value reflecting no data.
