001277: "Record Dates in" cannot be modified when already tracking dates in UTC/ Database time.
Editor tracking is already enabled on the dataset, and you attempted to switch from UTC to Database Time or vice versa.
Solution
To switch between UTC and Database time, disable editor tracking; then enable editor tracking with the new setting. You can also change this property on the Dataset Properties dialog box.
